Endat's Avatar
Engine stand bolts
Ok, so I wanna put my old 944S engine on the stand for a rebuild... where can I get some bolts that will fit the block, and do I have to take off the clutch before I put it on the stand?
Local hardware store was no-go... and should I also get 2 nuts and a load of washers?
Thanks in advance,
Endat
Old 07-22-2010, 11:39 AM
That Guy
Techno Duck's Avatar
The crossmember bolts work well, depending on the stand, you will need a few washers so the bolts dont bottom out in the block first. The bolt is a M12, i dont remember the length but M12x75 or so should be good.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-22-2010, 12:29 PM
Endat's Avatar
Thanks Techno Duck.. where do I order something like that?
Old 07-25-2010, 09:34 AM
Thats a standard size, just go to a local place or Lowes and they should have them in the loose fastener bins. They should also have them on the fastener rack at any chain auto parts store, but usually come in packs of 2 so it can be pricey.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 07-25-2010, 09:47 AM
968 GUY's Avatar
Do you have an auto parts store in your town? How about a Fastenal?
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 07-25-2010, 09:53 AM
yea u need to take off the clutch cause the bell housing holes is where the stand is gonna attach.
2 of the bell housing bolts are long enuff to use with engine stand. u'll need 2 more. it's M12 1.50 pitch. 90 or 100mm
try sears, true value, ace hardware. they carry them...cause that's where i just got mine. i'm in middle of a engine rebuild right now. just got the engine on the stand a couple hours ago
Old 07-25-2010, 01:04 PM
