-   -   Speed,Reference, & Timing Sensor (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/555034-speed-reference-timing-sensor.html)
3D914 07-24-2010 05:23 PM
I cannot find any reference in the Haynes manual, nor on this forum about the third sensor that connects to the sensor bracket. From the parts catalog, it appears to be a timing mark sender - is this correct?
Secondly - is there any adjustment for this sender/sensor?
Picture is from Clark's Garage - modified to indicate timing mark sensor.
http://forums.pelicanparts.com/uploa...1280017361.jpg
TIA,
kfray 07-24-2010 06:21 PM
This sensor is only used by the Porsche dealer mechanic connects to Porsche test equipment.
If you follow the lead you will find a connector mounted to a bracket at the back of the camshaft housing. This connector is not connected to anything. I removed this sensor and blocked the hole.
