kvnhpnr's Avatar
Instrument Clutser
I have a 1986 944 non-turbo and I was driving down the road today and the instrument cluster needles all just dropped (speedo, tach, battery, oil pressure gas gage and temp needles). I checked the fuses and the are good, there were only 2 under the hood. I also took the cluster out and didn't find out anything wrong with the wiring to the cluster also the odometer and trip meter quit working along with all the others.
What would cause the cluster to drop like that?
Another problem is that the lights for the cluster are not very bright...could 1 have those gone out and caused my previous problem?
Old 04-10-2010, 04:52 PM
Strange Electrical Issue (Sunroof/Instr Clust)...
My problem waas a bad relay.
ecostello
Old 04-10-2010, 06:17 PM
kvnhpnr's Avatar
Instrument Clutser
Where is that relay located since it is not on the diagragm under the lid for the fuses under the hood?
Old 04-11-2010, 02:31 PM
It is the X relay, look in the owner manual for the location.
Good luck, George Beuselinck
Old 04-11-2010, 04:29 PM
kvnhpnr's Avatar
Instrument Clutser
Imagine this...the everything started working again>>>I now have to re-align all the needles...what is up with the thing I call "Frankenstein" and it seems like it is fitting sometimes.
I never did get an owners manual with this car since I am the 3rd owner and really have no idea how many ACTUAL miles are on this car.
Thanks i will see if I can locate the X relay on the net
Old 04-11-2010, 04:41 PM
kvnhpnr's Avatar
Instrument Cluster
Well disregard my last post since it has now stopped working again...seems to do it if the engine heats up.
Old 04-12-2010, 01:43 PM
Porsche Addicted
bnv944's Avatar
mine does the same thing. Seems to happen after engine is up to temp, and any bump in the road triggers it to drop =/. anybody find a solution yet?
*1987 944 n/a. project car.
*1989 mazda B2200 beater <-- Update: sent away to be made into IPODS. RIP huebert
*2001 Jeep wrangler SE - THUMPER
"when the wrench starts to turn, but the bolt does not.
The project will take, longer than thought."
Old 07-27-2010, 10:04 AM
unindicted co-conspirator
looneybin's Avatar
could it be a loose ground connection?
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 07-27-2010, 10:07 AM
OnTheRun2's Avatar
+1 on bad ground
(Mae) Red '86 944na- gettting new paint soon.
(Abby) Black '86 944na- new addition to the family.
Old 07-27-2010, 01:02 PM
scottrx7tt's Avatar
could be the ignition switch.
Old 07-27-2010, 01:13 PM
968 GUY's Avatar
Do a search for your bulbs, or go to Clarks Garage, that site has good info on the bulbs.
My speedo stopped working on the 968 once, but it was just the connector had popped loose. I definitely would check the relay.
Ken
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 07-27-2010, 01:42 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
The x relay is listed in the diagram in the lid of your fuse panel. If that label is missing, stand on the drivers side of the car, open the fuse panel. Look at the relays, starting with the row nearest the lower bank of fuses (running lengthwise to the car) count up to the third row (second from the top)....now count in that row (from the front of the car) to socket G14 (the 4th socket in that row, it's actually numbered but very small). The x relay is G14 (the large squat relay). It's called the Ignition X Relay and available from pelican parts under part number 191.937.503.M206 at a whopping 5 bucks.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 07-27-2010, 05:38 PM
968 GUY's Avatar
Why would you have to realign the needles?
Old 07-28-2010, 05:51 AM
Under the car
I would just about bet money on the relay as well. Have someone watch the gauges while you wiggle the relay. See what happens.
Kvnhpnr, how long have you had the car? What color is it?
Old 07-28-2010, 06:22 AM
Check out the link below for the name and location of all the relays on your car.
944online.com Exploded View Porsche 944 Diagrams.
Cheers,
Larry
Old 07-28-2010, 01:04 PM
Porsche Addicted
bnv944's Avatar
Originally Posted by matthewb View Post
I would just about bet money on the relay as well. Have someone watch the gages while you wiggle the relay. See what happens.
well i took your advice, replaced the relay, thought "wow awesome, my problems are fixed!" then the gages went flat again while driving.. not even a pot hole to trigger it.
and when i wiggled the relay before and after being replaced, i did get response from the cluster.
Old 08-06-2010, 06:01 PM
So problem solved right?
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 08-07-2010, 11:21 AM
