-   -   sway bar? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/557966-sway-bar.html)
mayPOR944 08-09-2010 08:31 PM
sway bar?
my n/a porsche 944 has no rear sway bar would adding one make a difference i just bougt a used oem one with mounts for 30 bucks not bad.
ewalt98 08-09-2010 09:21 PM
Yes, for sure. Mine also didn't have one, and the car understeered. Adding one, along with a slightly bigger front made the car much more neutral.
I would say, my car is much more fun to drive, but it certainly isn't a track star.
As others have mentioned, you might find that a change to you suspension will highlight other areas that need to be addressed, either to compensate for the new rear bar (like a bigger front bar), or amplifying worn components.
Clarks Garage and 924.org have a nice write up on the affects of various suspension components to your ride and handling.
mayPOR944 08-11-2010 07:10 PM
just installed my sway bar today, it defintly made a good difference
