944 reference sensor connector
I just picked up a non-running 1984 944. I figured out the problem is a broken wire at the reference sensor connector and I was wondering if anybody knows where to get a replacement other than from a busted sensor. I don't really want to pull the sensor because I've seen plenty of horror stories with getting them out. I'd much rather just put a new connector on the end of it. I didn't see any shielding, so I would imagine a used one soldered on would work just fine, too.
Did you check the sensor resistance per Clarks?
Speed and Reference Sensors - Checking, Replacement, and Adjustment GL & welcome John |
I didn't, but I temporarily reconnected the broken wire and it started right up. I just need to redo that connector permanently. I've found a couple places that have the AMP connectors for quite a bit less than even the BMW cross-reference part for that.
| All times are GMT -8. The time now is 12:03 PM. |
