Interior light won't turn off
The interior light in my 88 turbo won't turn off. It can be turned off at the switch, but the door contacts have no effect. The contacts at the doors have been cleaned, but no dice. Anyone encountered this before? Thanks.
Old 08-19-2010, 10:53 AM
James Chimney
mine pops on when the rear hatch is not closed completely, have to get out and hit it down.
Old 08-19-2010, 03:14 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
More than likely one of the switches is bad or maybe need adjustment. Easy fix and the new parts/switches are not that expensive.
Four switches - One on each door, one on the rear hatch, and one in the glove compartment. The Glove Compartment switch is simular to the others but on a different circuit...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 08-19-2010, 04:02 PM
Turns out the switch on the hatch was looking for some attention. Thanks.
Old 08-20-2010, 02:50 PM
