joeporsche1's Avatar
Electric mirrors
Has anyone found out what wires do what on our electric mirrors ?
The green and brown run the heat to the mirror, after that theres 4
wires that go to the motor.
A brown I assume is ground. These are followed by a blue , a white , and
a black. if the brown is ground that leaves 3 wires for 4 functions. Any ideas on
this. Where would one try a positive power lead to get motor movement using the brown as ground ??????????????????????????????????????
Like a blueberry banana smoothie with oranges & apples daily with vanilla n coconut if you like.
Old 08-23-2010, 03:26 PM
Misunderstood User
This is an early model mirror.
Pin 1 - Blue mirror motor
Pin 2 - Black mirror motor
Pin 3 - Green heater
Pin 4 - Brown Heater
Pin 5 - Brown jumper from 4 To 2nd motion
Pin 6 - White to 2nd motion
Send me a PM with yoour email and I will send you a pdf of the schematic.
The blue and black go to the motor which is the largest component in the molded white plastic piece (2nd pic).
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-23-2010, 04:16 PM
Thanks Ill be waiting for it.. ( maybe a leican will deliver it lol). I tried
different combinations of wires to a power source and only get it
either one to click..
Old 08-23-2010, 07:46 PM
