Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
JuiceMan's Avatar
How Much To Replace A Flywheel On 89 944?
Ok I have the chance to purchase an 1989 944 Automatic it's white and in excellent shape I can get it at a resonable price (below 4k) it needs a new flywheel and I noticed they are about $600. Thats a steep price what I am wondering is around how much labor a project like this usually costs? Is it a really invloved repair or what?
Also do I need to replace anything else when I do this?
1969 Porsche 912 <- Sold
Old 01-07-2002, 07:21 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Scott R's Avatar
You can get flywheels for cheaper. Used from any number of sources will be less. I can only guess since a clutch job is between 10 and 14 hrs that a flywheel would be about the same since both jobs require removing the bell housing. Since I don't know much about the autos there may be more or less involved. But if I was going in that deep I would make sure that I was replacing the rear main seal, and possibly the pilot bearing. Also you should get new fly wheel bolts as they are designed to stretch when tightened.
2005 Cayenne Turbo
2012 Panamera 4S
Old 01-07-2002, 08:08 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
On the manual transmission the tranny must be dropped, the torque tube pulled back, the clutch removed, and the flywheel taken off of the engine. This usually costs $1500-2000 at a porsche mechanic including replaced clutch parts (but not flywheel).
I think it would be similar for an auto except harder. Try picking up a Haynes manual at an auto parts store and looking over the procedure. While you're in there you might consider replacing some stuff (rear main oil seal, clutch parts - or their auto analogs).
If you're considering doing it yourself and like to work on cars then it may be fun but you could probably find a good condition 944 for $4k without the problem.
Take a look at the 944 faq: http://www.connact.com/~kgross/FAQ/944faq.html
Good luck and keep us posted!
CD
1985.5 944 N/A
Old 01-07-2002, 08:16 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
lordgrommit's Avatar
Would have to be more like below $1500 for that kind problem any NA that you can drive away should be less than 4K . With the auto ( not desirable ), not running ( not desireable ) the rest should look like it came off the factory floor for anything more than I'd say 2k.
Matt
Prob the flex plate not the Flywheel but I could be wrong
Old 01-07-2002, 04:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
