Clutch pressure plate bolt question.
Should you be able to see parts of pressure plate bolts through timing mark hole?
To shake all doubt that nothing has come loose I need someone to tell me that it is normal to see part (20mm or so) of some of these bolts through there.
1990 944 T: 100 000 km/63K miles, 1997 986 2.5L: 95 000 km/60K miles, Living in the trackless land of plenty! |
In the Fires of Hell.....
They should NOT be sticking out past the PP, if that's what you are asking about. At most 1mm.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
I should have taken a photo.
I can't see the edge of the pressure plate through that hole, so I don't know. What I see is the middle of the bolt. No head.
