Flex plate line up
Hey, I would like to get some advise when installing the damper plate. I got it all done but for some reason when I go tobolt the damper plate to the flywheel the bolts dont line up.So can someone give me a little guidance into how i can get this all lines up, thanks
Can you have an assistant turn the engine via the crank bolt while you watch underneath for alignment?
yeah i figured it out, just had to take off the bellhousing a third time, since i like dropping bolts in the sensor hole, and just lined up the motor timing marks with the plate
