85Porsche944's Avatar
Rattle Between 2800-3000 RPMS
Man, this is driving me crazy. I have looked for the source of this rattle to no avail. It sounds like it is coming from the front of the passenger-side of the engine or exhaust. It sounds like maybe a heat shield, but I have checked them.
Anyone have any ideas?
You can feel the vibration also, but it feels like maybe 2 thin sheets of metal vibrating against each other. I have new motor mounts, new control arms, new steering rack and tie rods, but they are all tight.
Old 09-09-2010, 06:40 AM
unindicted co-conspirator
looneybin's Avatar
check the exhaust mounts.
There is a rubber mount up in the torque tube that looks like a pigs snout.
Make sure it's all the way in.
I've had the rubber get dislodged and make a terrible rattle at about the same RPM
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
'86 944 - Wilks PP2, strut brace, harness bar, M030 sway bars, 200# springs, koni adj, throttle cam, K&N filters, momo wheel & shift knob - faster in the twisties than a mustang
Old 09-09-2010, 07:03 AM
Proprietoristicly Refined
John_AZ's Avatar
There is a 2 bolt heat/dust sheild at the bottom/forward of the bell housing----Protects the FW.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-09-2010, 08:34 AM
your average wrencher...
have you done your belts recently? lower b-s pulley off?
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 09-09-2010, 09:16 AM
strikinglight's Avatar
my car does the EXACT same thing. I thought I had checked everything. It sure does sounds like a heat sheild making the noise. I will check them again tonight and report back.
Thanks John!
Old 09-09-2010, 09:28 AM
I did the belts on Saturday. I pulled everything off the front of the engine to replace the right gear carrier, but I that's not the problem. It was rattling before I did the job. Man, it gets so loud for a second that you can't barely hear the engine after about 2700 RPMs until it hits 3000 RPMs.
Old 09-09-2010, 10:10 AM
Redline Racer
HondaDustR's Avatar
Have you tried getting someone to hold the rpm so it makes the noise while you climb under and find it?
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 09-09-2010, 10:31 AM
It's weird but it does not make the sound when the car is stationary. It seems to be louder when in gear moving forward.
Old 09-09-2010, 11:13 AM
smokin_944's Avatar
Holy Smokes! Have you had the front wheels off lately for one reason or the other? I recently replaced my dust shields with the new ones and torqued the bolts 2 lbs over spec. Right after that, At 2600-2800 RPM I got a rattle in the front that I couldn't identify. It was the new dust shields rattling because they were a little overtorqued. Now that was bizarre!
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 09-09-2010, 04:13 PM
i'd double check your lover bs pulley because it is easy to put on wrong then it will be 180 out...if you just recently acquired the car, i'd definetly check and not rely on the PO's say-so. my PO for my car needed a good whack to the head.....idiot.
1982 931 *project*
Old 09-09-2010, 05:19 PM
No, it's not the lower BS pulley. Lined up the marks myself Saturday. It's also not the dust shields either. I took them off last night, but it still has the rattle this morning. I am thinking maybe the exhaust somewhere. I will let you all know when I find it.
Thanks, you guys are great.
Old 09-10-2010, 03:43 AM
Shifter's Avatar
It is the upper heat shield on the front of the exhaust. It isn't loose, but what is happening is the upper rear end of the shield is reaching a harmonic at that rpm and hitting the header. At least that was what was happening with my car. It was so loud, that was all I could hear at that rpm range. I just bent the shield away from the exhaust and the rattle went away.
89 S2
01 325
71 Alfa Spider
Old 09-10-2010, 08:22 AM
No to resurrect a thread, but did anybody ever figure this out? I recently restored a 944 and there is a rattle at this exact range.
Sent from my SM-G955U using Tapatalk
Old 11-01-2017, 06:51 PM
climb under the car and take a good look at the exhaust and how close it is to the body/heat shields/etc.
find the spot where it is closest to touching, loosen the exhaust hanger u-bolts and shift the system a little further away, tighten and re-check.
my replacement cat was rubbing on the front body heat shield like this.
Old 11-02-2017, 07:08 AM
GL
John
Not sure what a FW is, and may be the same but I had a similar rattle and it was the heat shield for the oil level sensor on my S2. It is cantilevered pretty far out from the mounting flange, and was cracked completely through one mounting hole, and partially through the rear. It was singing at idle through 3K RPM. I think bad motor mounts may have hastened its failure.
Old 11-02-2017, 09:01 AM
jhowell371's Avatar
Don't forget to check for a loose O2 sensor, been there, done that
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 11-02-2017, 01:54 PM
I don't have the oil level sensor, though it's an 87 and has the wire, i think the previous owner swapped pans. I'll check the other areas
Old 11-04-2017, 05:13 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
