Porsche Addicted
so at noon today i have emissions. i have no cat and a custom exhaust. they passed me before with a cat on that i later found out (when i took it off) that the honey-combs inside were in pieces. i need any cheats for passing without a cat ASAP plz.
*1987 944 n/a. project car. *1989 mazda B2200 beater <-- Update: sent away to be made into IPODS. RIP huebert *2001 Jeep wrangler SE - THUMPER "when the wrench starts to turn, but the bolt does not. The project will take, longer than thought." |
unindicted co-conspirator
if you have a visual inspection then you're toast
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Porsche Addicted
i know
Since a visual inspection is part of the process, you're toast.
You could have a cat installed, that would fix your problem!
~Chris 1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear 1993 Jeep Cherokee - 3" Lift, 30" tires |
Redline Racer
Dump the pieces out of the old cat and put it back on. It'll pass visual since it looks like a cat. There's no way they will take it apart and look inside. It's possible you could pass if your car is running really well.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
