Round or rectangular
I want to replace the crappy fog lights with something of better quality. The Factory Foglight Option was Hella Rectangular style, however, I can't decide if I want to be true to the factory option or use Hella Round style foglights.
I will leave it up to you guys to decide. I can go either way (round or rectangular, that is). |
Oem
Edek:
I am kind of a purist, so my vote is for Factory (OE) options. SmileWavy |
I'll gooe but with something like these which would ligth up your world,I wanted better ligthning from those crappy fog ligths but retain the oe look ,so what I did is install a set of Bosch Pilot clear lens inside the oe casing in order to retain all the attachements,this is a DIY job if need more infos just contact me.:)http://forums.pelicanparts.com/uploa...1284165528.jpg
I vote for rectangular Bosch . Great job Ernie ,those look absolutely great ! I also like the side trim pieces on them 951 style , as soon as i finish my car i will get a set of those but with amber lens , and i also want to get french amber driving lights.
Dang those are nice Ernie!! I need more info Ernie. This is an upgrade I need to have!
Wow those look really nice.
Ernie - I really like what you did and look forward to your DIY information.
Ernie, I agree with joeporsche1 and ddbach. We need the DIY on those bad boys. Fine looking upgrade!
It looks as though you cut the original lens middle out and left the edges to hole the new foglight in? What did you use to cut the glass of the original lenses? I'm always nervous when it comes to cutting glass and avoid it if I can.
Ok guys some 8 yrs ago is a long time to remember how you DIY a little project,specially when no pics were taken,the car was sold last summer & presently store in a garage the owner being away.But I got perm to go in & take a look at it & take a couple of pics .In order to have a real good look I would have had to remove the complete fog ligth assembly, meaning jacking the car, removing the wheel ect ect .This it is the best I can do.http://forums.pelicanparts.com/uploa...1284325648.jpghttp://forums.pelicanparts.com/uploa...1284325733.jpgV11 your rigth I cut rigth behind the flange that hold the class part of the fog ligth(first pic)& kept the back portion of it so I could fasten to bracket #3.It is difficult to cut since your cutting on an angle so taking your time is a must. http://forums.pelicanparts.com/uploa...1284326529.jpgin this pic you can see portion of the casing with the holes in it that you'll have to reuse in order to fasten to the oe brackets,you'll have to reuse those holes on both side.http://forums.pelicanparts.com/uploa...1284326881.jpgThis is the Bosche pilote casing once it's glue inside the oe one,also wires will have to be splice in order to make them long enougth to reach the Bosche Pilote connections. http://forums.pelicanparts.com/uploa...1284327600.jpg
http://forums.pelicanparts.com/uploa...1284327663.jpghttp://forums.pelicanparts.com/uploa...1284327932.jpg intalling it back http://forums.pelicanparts.com/uploa...1284327981.jpgBoshe pilote ligth retainers http://forums.pelicanparts.com/uploa...1284328041.jpgLOL peace of cake:D I do remember assembling the set up out of the car & just sliding everything in after ,Don't remember for sure but I think I had to use shims in there to get the rigth angle,very important (the glue ) i will find out tomorow & let you guys know what I use,it a two parts epoxy (black & grey ) mixes together can't remember the name but once it bond nothing can it it apart. |
Looks great. Where can you purchase the bosch pilot light retainers? I mistakenly thought you cut the original foglight glass but silly me, that's not how they mount.
http://forums.pelicanparts.com/suppo...s/beerchug.gif |
Wow,i can't believe you went to his house and took it apart ,amazing effort ! Thank you very much Ernie for the write-up !!!
| All times are GMT -8. The time now is 05:44 PM. |
