3D914's Avatar
Filler tube broke off in engine! What next?
I was removing the filler tube to get access to the engine ground behind it. When I lifted it off I noticed a small black piece drop down inside the upper breather port (see pic2). By looking at the end of the tube (sorry for bad pic-need a new camera) it looks like it melted.
Does the interior channel (see pic) return to any where vital?
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 09-19-2010, 02:52 PM
i have a good oil fill for $19.44 shipped to your door nine01@sbcglobal.net
Old 09-19-2010, 03:49 PM
It goes to the oil pan. You've got trouble if pieces dropped down there.
Old 09-19-2010, 03:53 PM
cjpacitto's Avatar
Hard to tell from your picture, but that looks like crud built up inside the port. That port should just be an open hole into the air/oil separator.
Old 09-19-2010, 05:08 PM
Redline Racer
HondaDustR's Avatar
Well, if you're lucky enough to have an oil level sensor on the oil pan, you could remove it and poke around with one of those little grabber things and a flashlight to get the pieces out. You do have a screen on the oil pickup, so it probably isn't the end of the world, but it would be worth trying to fish out the pieces. If they aren't trapped in the baffles, you may be able to get them out by just jacking up the drivers side of the car to tilt towards the oil pan drain and hope it comes out with the oil.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 09-19-2010, 09:21 PM
