Sunroof not releasing
Greetings all,
After going all summer without an operable sunroof I am finally trying to sort everything out. One gear is stripped and the gear is ordered but I also have another problem which does not appear to be related to the stripped gear. With the sunroof removed so there is no load on the remaining good arm: The sunroof will lift and lower to the latched position ok with the console switch but using the console switch I cannot get the arm to retract fully so that the roof can be removed (there is no voltage to the motor when I tell it to retract the arms). I can retract the arms manually to the unlatch position using a wrench on the 21 mm nut on the motor and once the arms are retracted I can power them back to the latched position with the console switch so I know the ignition is in the right position and the rocker switch is energized. any ideas where to look before I just start going point to point with my meter. Thanks, Jon
87 924S 82 924-Gone. 80 924 parts car-Gone. |
It sounds like you have a bad relay. Clarks garage has a nice write up about it and so does pelican. I love the sunroof although mine is on permanently for the winter. Miss behaving slip clutch and gears!
It's the #1 limit switch. Anyone have a source and part number, Pelican doesn't seem to have it.
Thx, Jon
Location: In a dumpster behind Albertson's in Los Angeles County
Are you referring to the micro switches (2) on the motor assembly? If so, the part number is:
944.613.127.00 for vin numbers above 92HN4 50198
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ![]() 1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Found it here on Pelican and it's ordered. Thanks.
Jon
