"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
Porsche Crest transaxle
i unbolted the trans and and moved the shift linkage out of the way but it is stuck the clamp wont slide down and both of the bolts are off
Old 09-24-2010, 06:09 PM
you should always slide that sleeve down before you unbolt the trans to keep it in alignment and not put stress on it
Old 09-24-2010, 06:12 PM
That Guy
Techno Duck's Avatar
Try a prybar, otherwise bolt the transmission back up to bring everything back into alignment. The coupler should be the first thing you disconnect (and slide back) before removing the transmission.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-24-2010, 10:14 PM
mayPOR944's Avatar
ight thanks will try that tommorrow
Old 09-24-2010, 10:18 PM
