Bell Housing Partial Removal W/Fork Installed?
Engine is still out of the car, and I forgot to reset the speed sensor prior to reinstalling the bell housing. I know I can do this after the fact, but I'd rather use a feeler gage between the sensor and the toothed ring, rather than do the procedure which involves gluing a .8mm washer onto the bottom of the sensor.
Thing is, it was a PITA to hammer out the clutch fork shaft, and I'd rather not do this again anytime soon. So my question is: can I remove the bell housing bolts and back the housing off enough to get a feeler gage under the sensor...while the clutch fork and its shaft are still installed? I know I could just go ahead and try this, but I don't want to damage anything in the process. Thanks! |
Automotive Necromancer
Negative
No, IIRC, you need to take the bell housing off which entails removing the fork and pulling the pivot shaft. As it hasn't had years and thousands of miles to rust and settle in, it may not be all that hard to remove. (lets hope)
Alternatively.....and what I would do if I were you...Take some card or plastic stock and glue it to the end of the sensor. I use a matchbook or thick business card. Once you install the sensor, the plastic or cardboard disintegrates when the engine runs leaving you with a perfectly gapped sensor. Viola'!
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
Location: In a dumpster behind Albertson's in Los Angeles County
on my old 89NA, I folded tape to the required .80mm, adjusted the sensor and left the tape in there. It worked perfectly. Now on the turbo, I would never even consider doing it this way...just the thought of any foreign object in there makes me shiver. Now I have an old sensor that I cut the wire off of, glued a washer on that, and have a permanent tool for adjusting sensors
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
fyi
Oh yea, and IF you removethe BH, notch the bell housing if it hasn't been notched already in order to use the feeler gage method.
