MK1 camber plate-any opinions?
Has anyone had any experience with the MK1 camber plate?
Are you talking about the mookah (or w/e) camber plates that are on ebay for $99?
If so, there has been mixed reviews. They use a cheaper bearing in the camber plate that needs constant grease or it will freeze up.
81 931 -efi via some megasquirt stuff |
Junk IMO...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
I think i was on the positive side of those "mixed reviews", but mine went bad recently.
Check out the Ground Controls, they're the cheapest you can get away with. Or i'll sell you my Mookehs for only $10/shipped ![]()
~Chris 1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear 1993 Jeep Cherokee - 3" Lift, 30" tires |
Thanks for the heads up. If something is too goo to be true, it usually is.
Thread Tools | |
Rate This Thread | |
