Anyone done this shifter repair
Tech-july-03
In this one you drill out the shift rod. I want to do this and am curious if anyone has done it without dropping the transmission. Also what kind of drill bits did you use? About how much did they cost? Any other tips would be helpful. |
Toofah King Bad
Dropping the WHUT? Dude. . .
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Proprietoristicly Refined
You can do this by just taking out the torque tube...
my retaining clip on shifter broke. so I 'updated' it... - Rennlist Discussion Forums
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
In the Fires of Hell.....
I did the 924 bushing fix, and did it just by raising up the shift rod after removing the shift lever. You can drill it out from inside the car without much difficulty.
It makes everything better from a shifting perspective. Throw in a short shifter at the transaxle linkage, and it is as good as it gets for these cars. Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
You can drill it out to oversize the hole inside the car.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
I know speedy has completely replaced that little rod that wears out...
dolor et pavor Copyright |
I replaced the lever and its great. still some play but its more than tolerable for everyday use. That is if you are willing to pay $54 for the thing.
