All Spooled Up
Here's Some K26 turbocharger info - mostly for 931's (& Audi's).
K26 #6 turbine wheel - 48mm minor diam, 54mm major diam
#6 turbine housing minor bore = 48mm
#8 turbine housing minor bore = 55mm
Four numbers trailing the "K26" =
example, '79 RoW 931 K26-2470
"24" = 2.4" diameter for the compressor exducer (61mm)
"70" = compressor inducer is 70% the diameter of the exducer (42.7mm)
"R" - still unsure about this...
"6.10" refers to the turbine wheel, there's no rhyme or reason with KKK's numbering system here. For example a 5.10 could be larger than a 6.10 which could be larger than a 4.10. Stupid engineers...
The KKK part numbers have a little code too-
for example: 5326 970 7007
53 (?)
26 (compressor exducer)
970 (?)
70 (compressor inducer percentage of exducer)
07 (the last two digits look like version numbers)
931 Turbos:
79 M31.01 RoW
K26-2470 R 6.10
KKK p/n 5326 970 7007
compressor exducer= 61mm
compressor inducer= 42.7mm
trim= 49
compressor map: http://not2fast.wryday.com/turbo/maps/k26_map2.jpg
80 M31.02 US
K26-2664 G 4.10
KKK p/n 5326 970 6401 series I
6403 - Audi 200T '79 2.1L
6404 series II
6406 series III
6407 "
watercooled: 6411 - Audi 200T-III '84 2.22L
6413 - Audi 200T '81 2.1L
6415 - Audi 200T-II '82 2.22L
6416 - Audi 200,Ur-q 1/'83 2.1L
compressor exducer= 66mm
compressor inducer= 42.24mm
trim= 41
More info on the 6407:
Turbine housing p/n: 5326 101 6365
housing-exhaust diameters (reasonably accurate):
outermost 2 7/8"
inner 2 3/8"
innermost 2 7/32"
man-housing diameters:
outermost 2 1/16"
inner 1 21/32"
innermost 1 17/32"
81- M31.03 RoW
81-82 M31.04 US
K26-2660 GA 4.10
KKK p/n 5326 970 6020
6022
compressor inducer= 39.6mm
trim= 36
Carrera GT (M31.50)
K26-2660 GA 6.10
KKK p/n
Compressor cover part number 5326-100-5104
Compressor wheel 5326-123-2017
Turbine housing 5326-100-6328
trim= 36
924 Carrera GTS (GTR?)
Compressor cover part number 5326-100-5105
Compressor wheel 5326-123-2019
Turbine housing 5326-100-6330
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-04-2010, 07:16 PM
Send a message via AIM to flosho Send a message via Yahoo to flosho
Your link to the compressor map is broken.
-efi via some megasquirt stuff
Old 10-04-2010, 08:10 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
