Fan switch related to overheating?
I have done some searching and it seems like a pretty common issue on the 84s.
I just got done with my TB/WP service (put in a new thermostat obviously) but I still have the same fan issue.
the fan works, but it comes on late. Like, the temp is almost on the yellow before the fan kicks on. As a temporary fix I just drive with the AC fan on when its hot and the temp stays perfect.
would the fan switch be the next thing to replace? I already have the "low-temp" switch, but I havent installed it yet.
Or is there something else I should be looking at?
1984 944: M456 suspension, KLA strut brace, PowerPROM Race chip, Slotted rotors/performance pads, Only944 short shifter
Old 06-23-2014, 10:26 AM
sure sounds like a switch problem.
i have the low-temp switch and i never get to the middle of the range...ever. even going uphill with AC on in 100* heat.
Old 06-23-2014, 01:31 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
engine temp
the fan switch should match the thermostat temp rating. Regardless, a lower fan temp rating should make the fan come on at a lower temp.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 06-23-2014, 06:27 PM
Patrick
pfarah's Avatar
Exactly!
I had the same issue until I installed the lower temp switch then Bingo!!
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 06-23-2014, 06:29 PM
Great! good to hear. had to order a socket for it but it will be in soon. Thanks!
Old 06-24-2014, 09:03 AM
flash968's Avatar
makes me nuts where they put the fan switch on the 968. you really can't get to it without removing the fans themselves. on top of that, they put it right below the upper hose. yeah - coolant dripping on an electrical part is NEVER going to cause problems. just crazy
Old 06-24-2014, 09:25 AM
Yeah mine seems accessible. I shouldnt have to remove the hose. I think I can get it by just popping the lights up, and I may have to remove the airbox.
Seems simple enough (famous last words). This is my first porsche so I am learning as I go.
Old 06-24-2014, 09:29 AM
when they were designing it, they probably were thinking "who needs a radiator"?
Old 06-24-2014, 10:19 AM
flash968's Avatar
i can reach the switch just fine. can't get a tool on it though without removing the fans.
Old 06-24-2014, 10:44 AM
plays with toy cars
sausagehacker's Avatar
On the NA you don't even need to pop up the lights. I take the fans off to give myself more room though... it takes 3 minutes.
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 06-24-2014, 11:39 AM
Patrick
pfarah's Avatar
I also removed the fans prior to switch replacement. It permits one to properly torque the switch.
Plastic threads: 20 Nm = 14.75 ft/lbs
Brass threads: 28 Nm = 20.65 ft/lbs
Important: Please make sure you replace the fiber ring seal!
Old 06-24-2014, 06:19 PM
flash968's Avatar
re: seal - no kidding! sure fire way to have a leak is to try to reuse it
re: torque - very important to not over-torque. old radiators are rather brittle. i'd hate to see it crack because of trying to skip a step
Old 06-24-2014, 06:40 PM
Patrick
pfarah's Avatar
Hey, some guys get lazy... just sayin'.
As for the torquing process, I try to correctly torque everything whenever possible... Those nice T wrenches sure come in handy. Speaking of T wrenches, I purchased a Husky 1/4" drive unit from Home Depot a couple years ago and it actually came with a Calibration Certificate! The wrench was tested at a local calibration facility (just to be sure) and the readings were spot on. I then purchased their 3/8" with similar results, ended up saving a few hundred dollars over the truck brands (I do own a Snap-On 1/2" drive wrench) while achieving accurate results.
Old 06-24-2014, 07:16 PM
Update: able to do it without removing the fan shroud. It was tight, but the shroud flexes just enough to get the socket on. I did remove the top of the airbox. Baby is running cold as ice now! Thanks all!!!
Old 06-30-2014, 06:25 PM
Just one more thing. Both fans come in at the same time. Correct?
Old 06-30-2014, 07:42 PM
AFM #725
Gawernator's Avatar
The new part should come with the seal
Old 07-01-2014, 02:28 PM
