944 doors tough to open
I have to squeeze the crap out of the outer handle latch to open either door. White grease in the latch mechanism doesn't seem to help.
I am not sure mechanicals are going on inside the door. Is there something in there that is worth tearing into the door for?
Jeff
Old 10-07-2010, 05:00 PM
My passenger handle is a little tough to open and I found this and I'm going to try and find some time this weekend to do it.
Pelican Technical Article: 944 Door Handle TuneUp
Jackson
Old 10-07-2010, 06:54 PM
In the Fires of Hell.....
kdjones2000's Avatar
Fix it before you break the handles, as used replacement script (PORSCHE) handles are in the $200/pr range.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-07-2010, 08:11 PM
