Koni struts on early NA
I have a line on some Turbo Koni yellow adjustable struts for a nice price. From all I have read it seems they will not fit my 83 without using the spindles , hubs, arms , etc. from the Turbo. I can actually get all of this also but I also thought that this would change the offset of my OEM wheels and possibly mess up the camber and generally be more hassle .
I know I could just add a Koni insert to my Sach strut housing , but for the price I am getting the entire Koni strut for I was hoping there was some way to make these fit. Still looking for a rear M030 sway too. |
The 86 turbo is also the early offset so there would be no change to the offset.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
dkbautosports.com
the reason the late struts will not fit are that the mounting points for the strut is diferent . the early cars have a 1 mm fatter spindle and the 2 holes that bolt are also 4mm farther apart . but i did get a nice par of koni's off a 86 and did do alittle fab work to get them on the 84 i have . other than that there the same . i milled one mm off the spindle and longgated the lower mounting hole and the tacked a washer on were the new hole is . its been loaned out to 5 people for track uses and is still all good .
Tom Early '85 944 |
Toofah King Bad
If you follow through with the 86 951 conversion, guess what else you get?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Lindsey racing has the M030 bars...
Thanks everyone for the background. So if I were to use the 86 spindles and they are fatter, is the O.D. of the bearing the same from early to late ? Meaning could I use my 83 rotor and hub ? Actually , I guess not as it was mentioned that it had to be machined down. Sounds like I need it all to be a straight bolt-on, unless I want to do machining and welding.
As to going the entire turbo conversion route (lol) , I already have a twin turbo car and this NA hopefully will make me into a better driver in the corners as I cannot make it up with speed on the straights. |
buy the Turbo's, re-sell them for more $$$, get the Koni's for the early car
profit! |
dkbautosports.com
the early mounting point were the lower part of the strut were it bolts to the spindle is fatter than the late cars . the offset change was do to the ABS brakes so the rotors will not work from early to late . there are no parts that you can use from the late cars and just bolt on the early cars unless you change the hole suspension over . if your just looking for better braking with out changing the hole thing over you cound do what i did with my 948 aka 944 V8 . for 750 bucks get the wilwood front calipers from rennbay . they bolt right up and you will get the same braking as the 951 turbo cars brakes . i'm one of the people that is not a fan of the later 944 suspension . i don't like abs for racing i don't like the cost of the control arm and i don't like that you just can't get a set of fatter wheels for a 911 and bolt them right up and keep the same track the car has . on the 948 i run 15x10 fuch wheels in the rear and 15x8's front off a 930 . if you gusset the cheap early control arms they become stronger than the late ones for less then 1/2 the price .
Yep, I am thinking for the price I may get them anyway and use for trade bait if I don't use them. I really just wanted the adjustable struts as I feel I want to keep the steel arms as well after they are beefed up. Thanks again, I learn more each time as I have more background in Audi's than Porsche's.
