-   -   I'm not scared to spend money! I am going to join PCA and I definatly want some... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/56960-im-not-scared-spend-money-i-am-going-join-pca-i-definatly-want-some.html)
overkill 01-15-2002 04:31 PM
sorta turbo/super charger added! I dont think I can handle just an engine! So far I found out that if I add a turbo/super charger with 944S compression ratio the engine will so called blow up...right? Also, i found out that the head needs to be heat treated...right? I can lower the compression ratio, but that will cut down on my HP, but if i cut down just a little to keep engine from blowing up. The HP that is lost from the lower compression will be made up from the super charger. With upgraded intake/ intercooler/ fuel pump/ head/ ignition system/ chip/ exhuast...basically the whole nine yards, would it be safe for the car?
Roger Hall 01-15-2002 06:08 PM
Why
Why bolt on performance and then tear down the motor.
GO BIG OR GO HOME!
RaF944 01-15-2002 08:23 PM
wow do you incorporate a turbo/supercharger question in all of your posts?
