Rim fitment te37 on a 944
Could a 84 porsche 944 accommodate:
Front: 18x8.5 ET50
Rear: 18x10.5 ET40
tires:
215/35/18 Front. LOW PRO/stretch
245/45/18 Rear. Low pro/stretch
I would be willing to roll fenders and maybe slightly pull them.
Old 10-23-2010, 06:32 PM
smokin_944's Avatar
Nikolai, I run 8.5X18s in the front, 235/40/18 and 10X18 in the rear 275/35/18 but it seems to me that your offset is wrong. The offset you have sounds like it belongs on a later 944. You have a Series 1 car like mine. Hopefully someone here knows for sure what the offset is. I thought the front offset on my car was 23 or something like that. IDK for sure...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 10-24-2010, 08:06 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
To use late offset rims on an early car you will have to use 1" spacers/adapters all around.
Have pfun
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-24-2010, 08:34 AM
when did the offsets change for porsche 944's? I haven't bought one yet but I want to because I have these great rims haha.
Old 10-24-2010, 02:01 PM
Send a message via AIM to flosho Send a message via Yahoo to flosho
Do they make te37s in our bolt pattern even?
Sounds like the fitment would work with 1 inch spaces (which you may need if you need bolt pattern adapters).
-efi via some megasquirt stuff
Old 10-24-2010, 02:50 PM
yes they are 5x130. Somebody buy them so I dont have to buy a 944. these are $3500 just for the rims without tires. I will give you a deal with 6 tires!
Old 10-24-2010, 02:52 PM
So... do you have them already? I would just bolt them up and see if they fit.
Old 10-24-2010, 02:54 PM
I have the rims not the car.. I sold my 964.
Old 10-24-2010, 03:24 PM
That Guy
Techno Duck's Avatar
The fronts will probably fit a late offset but the rear offset is too low i think for a late offset car. I think those are more ideally suited for a widebody late offset car (C4S, C2S, turbo..etc). They will stick out too far for a normal body car late offset car, usually you want to run in the 60+ range for rear offset. They would probably fit an early offset car, but dont quote me on that.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-24-2010, 04:29 PM
Non Compos Mentis
With 215 / 245 tires, a 944 will understeer like a pig unless you tweek the suspension settings.
Old 10-25-2010, 09:37 AM
I didnt have any understeer issues with my 964/911. However I can see how it would be differnt on a 944. If somebody is interested in buying them they come with a 2 extra higher profile tires that are like new.
Old 10-25-2010, 12:14 PM
Non Compos Mentis
Due to the severe rear weight bias, a 911 will oversteer like a pig if equally-sized tires are used front/rear. The 944 has a near-perfect 50/50 weight distribution, so they are most fun to drive with equally sized tires all around.
The earliest 911s had pretty low power, but were still known as having diabolical oversteer until they started getting wider rear tires to compensate.
Of course, the tires are just part of the suspension system, so playing with spring rates, shocks, sway bars and alignment will all affect understeer/oversteer.
Old 10-25-2010, 01:27 PM
