Looking for the correct part/number
Anyone replace these rubber electrical covers and have the part number available....
I'm looking for the rubber protection boot that goes over the electrical push on connector (113945525) for the front turn signals...I am looking directly at the rubber boot cover and the part number on it says 944 61232900..but Pelican says cannot find number ????? So I look on the parts page and it is showing a rubber push on connector cover 431971866..is this what I am looking for...it's a special order and just hate waiting 2 weeks for it when it could be the wrong part see pic... http://forums.pelicanparts.com/uploa...1287202201.jpg |
i have been looking for the same things and am not having much luck either. mine have rotted to the point where they fell off
You could go to an electrical supply shop and buy some heat shrink tubing to fit over the worn boots. Get a size that just fits over the boots and use a heat gun preferable, or a hair dryer (weak alternate) to shrink the tubing. If you get the good heat shrink it will work quite well. Before you do this, check your wires to make sure they aren't frayed or corroded.
| All times are GMT -8. The time now is 11:22 AM. |
