3D914's Avatar
Question NO visible oil pressure
Finished installing a used 87, 2.5L motor (running when removed from wrecked 944) in my sons 87-924S. During pre-start, I attempted to build oil pressure with plugs out & Fuel pump disabled. Nothing reading on the pressure gauge, and the idiot light blinks while cranking.
Tried to prime the oil pump by feeding oil down the center tube of the oil filler. Still no pressure. If the oil by-pass has failed, wouldn't that create excess pressure?
One 944 racer advised starting is the only way to build proper pressure - really?
Help. Insights?
TIA,
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 11-05-2010, 10:37 AM
Proprietoristicly Refined
John_AZ's Avatar
From the top.
Make sure the car is level or the oil pickup may be sucking air.
Is the front crank bolt torqued to 150ft lbs?
Are you using an OEM Porsche or Mahle oil filter?
Are you using conventional 20-50 wt oil?
Did you pull the OPRV and check to see if the piston was not stuck?
Links:
Clark's Garage Message Board :: View topic - oil pressure showing 0 bars...help
Oil Pressure General Information and Troubleshooting Tips
Another good link:
priming oil pump - Rennlist Discussion Forums
Trouble getting oil pressure on new motor - Rennlist Discussion Forums
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-05-2010, 10:57 AM
Don't lose hope.
I got oil pressure after priming the engine thru the oil filter housing 10x after a headgasket replacement. I got frustrated and just like you almost gave up.
Keep priming, it will develop oil pressure.
Here was my ordeal.
Dropping the engine
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 11-05-2010, 11:41 AM
3D914's Avatar
OK, tried air pressure at dipstick - no difference.
SO I just decided to hook up the rotor and go. Started right up, and oil pressure came up to 1 in a few seconds, then climbed to between 4-5 bars.
Step one done. Engine idled for about a minute or so then quit. Sounds like more work to do.
Thanks,
Gerard
Old 11-05-2010, 03:05 PM
The newest of the noobs!
grendiers's Avatar
Yeah, if using heavy oil as mentioned, you should pop up to 8 bar at least till oil warms up.
1989 944 Turbo
2004 Jeep Wrangler Unlimited - Built!
1985 Saurer 6dm overland Swiss military truck/camper
Old 11-05-2010, 04:05 PM
Redline Racer
HondaDustR's Avatar
Yeah, I wish Porsche put 10 bar gages in the 944s, too. We've only got 5.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-05-2010, 09:13 PM
