thamlin000's Avatar
Angry Rear lights won't turn off
Help! My taillights and rear side marker lights won't turn off. One of my brake lights wasn't working, so I decided to replace all of the lights in my rear light assemblies (reverse, blinker, brake and taillights). Now my tail lights and rear side marker lights won't turn off.
What happened? How can I fix it?
Thanks for any input.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 01-20-2002, 12:54 PM
Are they lit on both sides? Did you make certain you installed the correct bulbs? I ask only because funny things can happen when dual filament bulbs are fudged into sockets made for single filament units. Also, look for a grounded return wire. Many circuits in the Porsche are "hot" with the key off such as sidelights (turn your directional either way with the key off and you will see what I mean).
Anyway, remove and replace one bulb at a time and see if any of them eliminate the problem. If it does, you are on your way to finding out where the problem lies.
Good luck!!
Bob s.
Bob S. former owner of a 1984 silver 944
Old 01-21-2002, 07:09 AM
adrian jaye's Avatar
This aint the parking lights ???
dont know bout US, but uk models, if you put the indicators on when parking (and lights on) if you switch the engine off, the side lights stay on, regardless of light switch posn, only way rounf it is to start engine, make sure indicator's are off, put lights on then off, then switch off.
I though this would only put the lights on one side though, left or right.
You proably allready know this, so just a suggestion
Adrian
Old 01-21-2002, 09:12 AM
thamlin000's Avatar
Yesterday, as a short term solution, I took out the bulbs. Today I put them back in and fiddled around with the wires and other bulbs and now there seems to be no problem. All fixed......I hope.
Thanks for the solutions.
Old 01-21-2002, 02:23 PM
