924 SC project
In order not to polute this exelent post, 944s supercharge , I start this new post to present transformations of the 924s 2.5L that is going to be supercharged !
http://924cup.fr/circuit/924S/924cs3.JPG i still have two engine a 160ch (cr 10.2:1) in my 924s, i could start to play with SC with 5-6 psi and engine management... and in the same time work on the other engine a 924s 150ch (9.7:1) to use the 951 piston for higher pressure... Engine Management will be Megasquirt... Sorry for my poor english level , it's not my native laguage :o |
C'est pas la fin du monde, mec... Je te souhaite la bienvenue de la part de tous! Welcome to the Pelican forum. There are many supercharging afficionados here... I'm sure they'll help out with any questions you might have...
thanks !
Indeed, i will need help of members... Most of piceces are coming... Phil |
Bienvenue _Welcome & good luck with your project _Bonne chance avec ton projet.( warning to all members the French are taking over)http://forums.pelicanparts.com/support/smileys/wat3.gif
I'd say your english is very good I probably wouldn't have even noticed if you didn't say anything.
I picked up a little french this summer when I went to Montreal. "Je ne parle pas français":D When I said a little I meant a LITTLE. Everyone seemed to think it was funny that I could only say that. Good luck with the project though sounds interesting. |
| All times are GMT -8. The time now is 02:02 AM. |
