pinball_0's Avatar
Anyone with source for 10K pot in HVAC
my 10K RUWIDO detented potentiometer in my control assy broke... I know most buy another assy and just replace however for the part that broke only being worth only about 5-20 dollars i hate to condemn this unit as it worked before my shaft broke
Any sources would be appreciated... other than cannibalization
Old 11-19-2009, 09:27 AM
Hi !
I was able to find one for my 44. Check Automobile Atlanta using this part no :
U477959530 . See if that is the one you need.
Old 11-19-2009, 04:37 PM
pinball_0's Avatar
the one you listed is for pre 85.5
Thanks, but the one I am searching for is inside the central control assy ... the right side knob (electrical part).
I attempted to use a off the shelf radio shack 10k linear pot but it is physically too big to fit without grounding inside on the illumination lamps (Ugggh)
Old 11-20-2009, 08:11 AM
Avoid rat shack parts for your german car
Quality 10K pots are available at mouser.com - no minimum order
I've used Alpha brand with good success although not in automotive applications.
PCB and solder tab, linear and log, 12mm, 16mm, 24mm. Not sure how small you need. Also these I'm linking to are typically only about a 1/4 watt, not sure how much voltage/current we are working with here.
http://www.mouser.com/catalog/640/usd/693.pdf
http://www.mouser.com/catalog/640/usd/692.pdf
http://www.mouser.com/catalog/640/usd/691.pdf
Other quality brands like Alps, Bourns, etc. would be fine too. If you order, you may want to order a couple options and see what works best in your application.
1987 944S
Old 11-24-2009, 10:47 AM
Thumbs up Faulty 10k pot in 964 ccu/hvac
G'day pinball-0, hope you are still active on this forum/site. If anyone out there has advice/suggestions for me also greatly appreciated. In a nut shell my air con/fan is intermittent, I have traced the problem to a cracked base in the fan speed Ruwido 10k pot, if I press on the fan speed knob firmly the little orange lights on the AC & air circulation switches light up & the fan works---then I drive over an uneven road surface (or hit a bloody kangaroo) & its game over--shut down until it is jolted on again whenever it decides. I am pretty sure this is a relatively inexpensive part, only problem is---where can i get the little sucker? Thnx in advance.
Old 11-23-2010, 07:35 PM
