mjl mjl is offline
944S Rear seat back
Alright, I'm attempting to re-install the one-piece rear seat back in my 87S. I removed it a solid 5 years ago and now don't have the foggiest idea how to put it back. There are two holes on the little metal mounting plates on either side of the piece, that would indicate a bolt would lock it down. But alas, I see know receiving holes between the lower seat portion and the side of the car. Anyone have any insight on this? I'm feeling rather defeated!
Old 11-26-2010, 12:41 PM
Are the holes you refer to for the seat belt bolts? I know that you have to use 3M Spray Glue to the back side of the lower seat and the car side and press them together. Sand bags work great to put pressure on the sets to help the glue fasten the seat and car body together.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 11-27-2010, 12:20 AM
mjl mjl is offline
It's not the bottom part of the seats, it's the top (the bit that lays up and down). The holes are on the bottom ends of that bottom piece and appear to fit somewhere in between the bottom seats and and the side of the car. But, I don't see anywhere on the car where they would mount.
Old 11-28-2010, 07:44 AM
RM512's Avatar
It mounts with a couple of shoulder bolts. They are kind of small, but there should be bolt holes somewhere behind the carpet.
Old 11-28-2010, 09:59 AM
Endat's Avatar
Why didnt you just fold the seat down?
Old 11-30-2010, 12:42 AM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
look lower. they're buried. I replaced mine, figuring it would be an easy time, and it took me two hours of swearing.
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 11-30-2010, 08:12 AM
