See through timing case cover
E-Bay 200511557245
Anyone try one of these? I'm not sure it has any practical value, but I kinda like it. |
Redline Racer
It reminds me of old hotrodded VW Bugs. It looks pretty now, but remember all that black belt dust that collects on the inside of the covers?
1987 silver 924S - Rebuilt motor! Survived 45K so far. Bottom end balanced, Custom mild ported head, Port matched intake, LR 944MAX chip, Thush Welded muffler, Bilstein shocks, no more K&N air filter, MSD Blaster 2 coil (no ballast resistor), Steel braided brake lines, Magnecore wires, Weltmeister throttle cam. Needs 8 more valves! |
Here's the pic from the ad. I think it's cool simply because it shows the complicated nature of the balance/Timing belts
Vern '74 911 Coupe - Silber Metalic (963-93) '88 944 - Nougat Brown Metalic '74 914 - Light Gray 2.0 |
the de-luxe version has a built-in vacuum nozzle woking off inlet manifold pressure to clean the plastic free of belt dust.
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear swaybar. Ford Focus 1.8TDCi estate daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
I might actually like one of these - so I could hand-rev the engine while watching the belts for any signs of misbehavior. Sure I can simply remove the upper belt cover to do this...but not likely in the rain in the parking lot of a 7-11 (or on the way to a business meeting, for that matter) when I think I hear a belt acting up. Think about it!
....ok, there'd be a bit of belt dust possibly obscuring the view - but when this turns to belt bits (which I bed I'd see stuck to the inside surface of this cover)...I'd want to know about this sooner rather than later.
Some of you guys are downright paranoid...
And I love to watch things work, but I see this as a good means to separate me from 120 that I could put to much better use....
Sidney J. 1986 944N/A India Red, Well Prepared ![]() 1987 924s Silver for now. Track rat in SlOW progress. Past: 1990 VW Corrado G60, 1997 BMW M3 Keep Calm and Carry On |
Garage Helper
A friend has the plastic see-through belt covers and in no time they are occluded by black dust and other debris - making them not see through. They are expensive also for what they are - molded plastic. He said there is more up keep on the covers than the belts themselves, and heaven forbid should they get scratched, inside or outside or even when cleaning.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
