-   -   Wiper Spray Not Functioning (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/578435-wiper-spray-not-functioning.html)
jep32 12-03-2010 05:41 PM
89 S2...where do I start to troubleshoot? Can't hear the motor functioning when I engage wiper cleaner.
Jrboulder 12-03-2010 05:47 PM
see if the pump is working and that the check valves are clear. mine were all clogged up. also check the nozzels as they can get clogged
ernie9944 12-03-2010 07:47 PM
Check the fuse first,since you can't hear the motor running (thereis no juice going to it).:)
jep32 12-04-2010 03:19 AM
beginner here.....gotta find the fuse
ddbach 12-04-2010 06:04 AM
There should be a diagram on the underside of the fuse box cover.
Mine is fuse #24, 30 amp
