a/c questions I searched past threads...
I found 1 person said a/c drains 20HP and another said 30, so either way its a noticable difference. My question- is the HP loss only there when you're using it or is it as long as the belt is attached to it? And 2- how much does the hardware weigh that you would take out if you were to take the a/c unit out? thanks
Pat |
I'd say a/c drains more like 10-15 hp if it's in good working order, and that is only when the compressor is working. The compressor part prolly weighs about 25# or so, i recently rebuilt my a/c clutch when it was on the car, didn't take the compressor out of the slot, but it should weigh close to that. Add about another 15# in hoses and such, about 10# for the condensor. (all guesses)
Yes, you definately feel the loss of power in a NA with the A/C on when driving around town. At highway speeds that changes alittle depending on if your windows are open or not with the A/C off. I would say that the added wind resistance at highway speeds with windows open and A/C off is higher than the power robbing the A/C compressor does to the engine and driving more aerodynamically clean with the windows closed. And the other benefit is it's much quieter at highway speeds with the windows closed. |
thanks- I definetly notice the difference when I turn it on but I wasn't sure if it made any difference while it is not on. I guess not- but if it is roughly 50 lbs for all the componants that may be worth it since I almost never use the a/c anyway. Thanks alot
Pat |
| All times are GMT -8. The time now is 10:47 PM. |
