CVJR's Avatar
Clutch pedal on the floor
I have a 87 944 I've owned for a month. 65k miles. Clutch master was replaced 3weeks ago under P mechanic's advice because pedal occasionally went to the floor. You could pull it up with your toe and get underway, once warm it would go away.
Hadn't driven for a week, so started right up tonight, but the clutch pedal is on the floor again. There is no tension at all, you can pull it up with your toe, but it will snap to the floor again the moment you touch it. Needless to say, can't drive the car.
What am I looking for here???
'86 Porsche 928S
'87 Porsche 930 Coupe
Old 12-08-2010, 03:04 PM
probably failed clutch slave or a bad hydraulic line between master and slave.
or maybe something mechanically wrong with clutch fork/throwout bearing/pressure plate fingers?
Old 12-08-2010, 03:12 PM
flash968's Avatar
yup - most likely the main hydraulic hose - they balloon up at the coupling and then rupture
always change all components in an hydraulic system at the same time - failure to do so will quite often result in the remaining component failing, as it is weak
Old 12-08-2010, 03:19 PM
Redline Racer
HondaDustR's Avatar
Luckily the clutch is bleedable with 1 person if you have long arms.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 12-08-2010, 03:40 PM
Toofah King Bad
Rasta Monsta's Avatar
Replace the slave and hose. . .pretty quick job, really.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-08-2010, 03:43 PM
flash968's Avatar
no long arms needed - get a motive power bleeder - done in minutes - no muss - no fuss
Old 12-08-2010, 05:07 PM
CVJR's Avatar
Thanks all, I'll check the suggested items.
'86 Porsche 928S
Old 12-08-2010, 05:40 PM
look to the line between the master and the slave, but first be sure it is bled
Old 12-08-2010, 07:12 PM
Quick test - pop the clutch inspection plug off. If you take a bath, the slave cylinder is ruptured.
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 12-09-2010, 10:37 AM
