Need help with oil leak
On my 83' 944, I have an oil leak coming from area behind the base of the distributor. I suspect the camshaft seal.
Question: How difficult is it to replace all the necessary gasket and seal, and where can I find instructions/directions to do this. I would appreciate any help.
Old 12-11-2010, 04:39 AM
Proprietoristicly Refined
John_AZ's Avatar
Ho Ho Ho
Bennington Motorsports
GL
John
1988 924S 77K July 2017 ...+ 1987 924S 145K DD (+15K est. bad odometer)
Old 12-11-2010, 05:07 AM
yarfk
kfray's Avatar
Info:
http://www.clarks-garage.com/pdf-manual/cam-03.pdf
Also check the balance shaft seals and the front crankshaft seal and while your in there the check belts and water pump.
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 12-11-2010, 05:12 AM
John_AZ's Avatar
Do not ignore step #22 above-Bennington....the cam bolt cannot be retorqued and has to be replaced=Pelican ~ $5
John
Old 12-11-2010, 05:23 AM
Thank you for the two sources of instructions......I should be able to take care of the cam seals while I'm replacing the timing and balance shaft belts.
Old 12-11-2010, 05:43 PM
