944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Painting the engine
If you're doing major work on replacing all seals and hoses like me, then I'm a big proponent of painting the major components of the engine. I pulled the intake manifold, cam tower, cam sprocket cover and have painted them. Also cleaned all the dirt and residue from other stuff in the engine bay. While the intake manifold was out, rebuilt the injectors, replaced aged hoses and one broken vacuum fitting under the J boot. Also replaced the AOS seals. More simply put, while you're in there, there's a number of things that can and should be attended to while you have access.
My cam tower and plugs on top were taken down to the bare metal (after degreasing) with a drill powered brass brush. Steel is damaging to the aluminum. Then cleaned with clean towels and carb cleaner and a spray degreasing pre-paint fluid. After serious masking of the letters and areas wanting to be exposed, sprayed with 2 coats of VHT engine primer, one coat of white to enhance the color of the red and then two coats of red. The cam sprocket housing is done in similar manner and stainless steel metal flake spray paint was used. This sound tacky but after the paint dries, it should be wiped down with a clean cloth and the flakes that sit on the surface are wiped off and it looks outstanding.
The intake manifold is out for media blasting because a wire brush won't get to the inner areas of the manifold but will be sprayed with the same stainless finish.
The pictures tell the story. Saved about $300 over powder coating.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 11-19-2011, 12:09 PM
Looks great! One option to masking all of the lettering is sanding after paint on the surface of the letters.
Old 11-19-2011, 12:51 PM
944 addict
I had considered sanding after painting but when I looked at the surface of the letters after I used the rotary brush on them I saw that they were very porous looking. It would have been a lot of sanding plus standing the chance of accidentally dinging the new paint job. The fine masking took an hour with a razor blade to trim and was definitely worth it. Can't wait to get the intake manifold back so I can paint it and get everything back together.
Old 11-19-2011, 02:10 PM
when i painted mine red like that i took it to my machinist and he milled off like 0.005 from the letters. i clearcoated over the whole thing, its still shiny 6 years later
Old 11-20-2011, 07:01 AM
9FF 9FF is offline
9FF's Avatar
If anyone wants color choice ideas for engine painting they should look at Albert Broadfoots work. Amazing!
Engine_Rebuild_Page
Old 11-20-2011, 08:10 AM
Thanks!
Originally Posted by 9ff View Post
if anyone wants color choice ideas for engine painting they should look at albert broadfoots work. Amazing!
engine_rebuild_page
86NA944
Old 11-20-2011, 02:09 PM
