Porsche Crest 951 wont start
I am having a reoccurring problem with my 88 turbo S. I have just recently put a Lindsey racing MAF on it and at first had no problems. Not sure if it has anything to do with the MAF. About a week ago the car started to idle rough then just died. I tried to turn it over a few times with results. it would pop loud when i turned the key off. i let it sit for a bit and it turned over w/ no problems and ran great. It has done this 3 times. and today it died in the driveway and it has not kicked back over. any ideas?
Old 12-23-2010, 05:33 AM
let it set for a bit and just went out there, started on first try. What could be killing it like that?
Old 12-23-2010, 05:40 AM
Few questions to help narrow down what may be causing this:
Is the tach bouncing?
Are you getting spark?
Are the plugs wet?
Have you looked at the condition of the Ref sensors? Maybe jiggle them if your car won't start cause this might be causing this.
Do you have a DME relay Jumper? If not make one and pop that in when this happens.
Report back with answers and we can go from there.
Old 12-23-2010, 07:17 AM
