Highest HP& Tq using K26-8 Turbo vs K26-6
Guy's and Gals:
Just wondering, what are the greatest power attainable from the Stock K26 Turbo's? I'm looking to upgrade my 16V for more power using the K26 Turbo's I have a K27 for rebuilding also for consideration, but not sure . It's going to be a low pressure system running to 4-7psi due to my ~11:1 compression. I know there is a ~ 30hp difference at between the 86-88 Turbo and the Turbo-S 88/89 vehicles stock. ;)Please feel free to post dyno's for visual references or PM Me. Thank you in advance Later |
Subscribed. Im sure it's more on a DOHC platform..
Does the Turbo S run more boost than 11psi on the K26-8?
Just wondering??? Any response would be greatly appreciated, Thanx. |
I think it runs the same boost on a larger compressor giving more cfm.. im probably wrong though
Same boost & same compressor as -6, but larger turbine. Provides more power at top end of rpm range.
K26/8 is at top of it's limit around 330 or so. But you need to run like 20psi (in a low comp engine) to see that. |
Latest info:
The compressor wheels on K26-8 is 46mm Ex and K26-6 is 44mm and also Turbine Exducer on K26-8 is 55mm Vs 48mm on the K26-6. The K26-8 tops out at 350hp at 17.64 psi while the K26-6 ends at ~310 around 18psi... Looks like the K26-6 spools up around 300-600 rpm sooner. Looks like a K26/27-6 is the way to go... for more flow and good drive-ability all around... What do you guys say? Good topic though. Later. |
I mean more like the K27-6 Right?
Later. |
