dally_de's Avatar
Send a message via Yahoo to dally_de
rear axle shaft play
well yes this is another problem of mine...
the rear axle shaft (the one that connect the cv axle with differential) is having a play..kinda big one (about 5mm)...can someone tell me what could be the problem ??
-porsche 944 n/a 85.5 on Eaton M90 diet
Old 12-28-2010, 06:01 AM
All Spooled Up
The one-word response to that would be: WEAR!
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 12-28-2010, 06:56 AM
Toofah King Bad
Rasta Monsta's Avatar
Depends which direction. If the play is in the rotational direction, you have a problem. If the play is axial, that is normal.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-28-2010, 07:32 AM
The tranny output shaft is fastened to the differential bevel gear with the long allen cap screw and then it rides on a plain sliding fit bore in the diff carrier so it should float axially. If the play is radial, that is wear on the diff gears.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 12-28-2010, 08:15 AM
Toofah King Bad
+1, that bizzarre guy is a genius.
Old 12-28-2010, 09:09 AM
dally_de's Avatar
yes it is axial play
this play is on left side(driver side) ,on the other side it isn't any play,and i didn't had this play before.that allen screw it is tight .
if i change the differential will that play disappear ?
also few times when i am driving in 2nd gear after a hard acceleration -if i leave it to decelerate it will shake hard the back of the car.
could this problem result form this play?
Old 12-28-2010, 09:42 AM
The back side of the driver side diff gear (bevel gear) that attaches to the output shaft maybe has more gap compared to the pass side. Maybe you can put a spacer about 3mm to reduce the axial play.
I had this shaking problem before especially when I downshift to 2nd from 3rd even if I match revs. It sounded like the torque tube was hitting the torsion tube housing in the back. Some people said it could be the exhaust but it was not.
It disappeared when I changed the clutch, pressure plate and machined the flywheel. It does not do it anymore when I downshift to 2nd. Maybe it was the clutch disc dragging between the PP and uneven FW surface.
In short a new clutch, new pressure plate and machine FW fixed the problem.
In your case, check first the easy ones like the exhaust hangers before you do anything else.
2018 Suburban Z71
Old 12-28-2010, 12:16 PM
dally_de's Avatar
hmmm...i have to look more carefully ...not it is allot of snow outside and i am not driving it ...i was scared that could be something from differential with that play ...
Old 12-29-2010, 02:26 AM
The clutch job was not really intended to fix the banging noise when I downshift to 2nd. I dropped the engine for headgasket job and just decided to do the clutch at the same time.
The problem just disappeared after the clutch job.
2018 Suburban Z71
Old 12-29-2010, 05:04 AM
porscha
matty89's Avatar
is ur play from left to right on ur drive axel or it while turning it the rotation it is suppsed to be i know i have alot of play from left to right but no one was able to tell me if it was bad or not !
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 12-30-2010, 10:13 AM
dally_de's Avatar
it is from left to right(in and out, not up and down or rotationally) ...but only on driver side
Old 12-30-2010, 10:58 AM
All Spooled Up
If you are referring to the axle shaft itself, it does need to have some movement, so the other side should have some in/out movement also. But maybe that side is just too tight to move by hand. On the other hand, maybe the side that you can move IS looser than it should be. Maybe it'll last a while yet though. It's when one of the ball cages lets go, that it is definitely time for a new CV shaft. But it WILL leave you sitting.
Could you post a pic or 2 of the engine with the blower on it?
Old 12-31-2010, 08:55 AM
dally_de's Avatar
Old 01-01-2011, 09:51 AM
