What did you get done in 2010?
Let's see here, what did you do to your p-car in 2010?
I bought 2 porsches in the last 4 months Did 1 944 clutch Pulled the intake twice. And took a lot of it apart several times. |
I bought mine in october, and so far I've changed the oil, air intake, fixed a broken sway bar mount, new street tires, and a few other minor things :)
supercharging my blue 968 (and 10 others) would be pretty high on the list
Bought 85.5 944 na in MAy, put over 7,000 miles on it, new tires, front Zimmerman cross drilled rotors and pads, 968 front and read sway bars (30 & 19) yellow Koni's all around, new shifter and boot, 5 or so Auto Crosses, one Porsche fall tour (PA with 31 other Porshce's) new rear cargo carpet, all fluids but power steering and anti freeze (next spring) still to do new Bursh exhaust (with cat elimination pipe and ceramic coated header sitting in garage) new chip, tune up in the spring, new floor mats.....ok ok now I am looking at 911/930's you can't own just one.
Bought my 951S...that's the biggest news! Am purchasing parts when they pop up to bring the car to 100%.
Neglected my 944S's timing belt until it sheared teeth--head rebuild, all new hoses, seals, belts, tune up parts and more since then. Put snow tires on it and I'm using it for my winter daily. 931--fixed the grounds to the motor, fixed a coolant leak, gave the keys to mom for her summer car. mom's 911SC--ignored it...it needs help and I need to clear time and space to pull the motor/transmission Superbird #1--sent to a body shop where it's getting fixed as I find money Superbird #2--finished an interior restoration, drove the car to Canada for a Mopar show, enjoyed the car as a summer cruiser. '69 Daytona NASCAR lookalike--Completed 5.7 liter HEMI swap to pick up power and mileage for long trips. |
Oh god! Let me see if I can remember everything.
In no particular order: Bought two sets of tires, 951 M030 sway bars, rear Bilstein shocks, bought a steering wheel for ten dollars, bought 15" Phone Dials and repainted them graphite, bought an engine to rebuild, took it apart brought the head and crankshaft to the machine shop and decided it wasn't worth the money, replaced lots of little things (door mirror, fog light etc.) stripped a lug nut and had to drill the stud out (boy was that fun :rolleyes:) bought a cobra sport seat from a fellow pelican/CVR PCA member, fixed my sloppy shifter, got my injectors rebuilt, replaced most of the vacuum lines, rebuilt my power steering pump, took my bumper pads off to "shave" it and compress the shocks (but I got lazy and just left it without the pads) ordered several hundreds of dollars worth of parts that still haven't been used (I'll get to it eventually) And the most significant, I decided to go to an autocross event "just to try it once or twice." I ended up joining the PCA two months later, went to all ten events (plus one nonPCA autocross) and wound up winning "Rookie of the Year." Autox kicks ass! I can't wait to see what I do with my car in 2011. I just hope I don't go broke:D |
Lessee. On my 951,
1)I fought with the ball joints - rebuilt them with the Rennbay kit, only to have one fail (the socket, as it turned out, was out of round), then installed newer control arms with good ball joints; installed new solid control arm bushings, then had the car aligned. 2) Installed a new sub and new speakers (a small powered, Kenwood sub and Eclipse speakers); 3) I rolled the fenders (they'd been scraping on bumps); 4) I changed the brake booster (and then afterwards, found out the problem was a blockage in the stupid vacuum line - d'oh!). On my 83 NA: 1) Installed new engine mounts; 2) Rebuilt both front control arms (new bushings and ball joints; replaced one tie rod; 3) Installed new left rear wheel bearing; 4) Installed new rear carpet; 5) Replaced the wiper motor; 6) Replaced the distributor cap and rotor. |
OK, my list would take a whole page, but here's the big ones:
- new exh mani gaskets - refurb the cooling system: radiator, all hoses, flush, etc. - 18mm rear sway install with prothane bushings - rear Koni shocks - front 25.5mm sway install with delrin inner bushings and braces - Swepco in the tranny - new O2 sensor - new rear wheel bearings, plus paint rear calipers and dust shields - clean all electrical grounds, replace all fuses OK, not as big as I thought, but still plenty of work on the old girl! :D |
On the 951S, I did the following in 2010:
Built a k27/8 turbocharger, and installed it on the car. Replaced belts, rollers, front seals, and water pump. Sealed rear of balance shafts. Replaced AOS seals. Changed engine oil & filter. Replaced rear hatch struts. Deleted power steering pump & reservoir. Upgraded camshaft to late grind. Replaced both CV shafts. Upgraded intake piping to full 3". Ported out both ends of turbocharger outlet pipe. Upgraded DP section of center pipe to 2.75" SS. Upgraded rest of center pipe to cat-free SS 3". (rear pipe is already 3) Separated waste pipe from dumping back into main pipe. Upgraded to delphi 55# fuel injectors. Replaced oxygen sensor. Deleted hard pipe tree under intake manifold. (lots more room now) Upgraded boost control hoses to silicone. Installed Nology power core on ignition coil. Fixed leaky wastegate. Installed A/F gauge and 6700rpm shift light. Replaced DME chip with Ostrich II emulator module. Installed remote door locking/unlocking. (also activates factory alarm) Replaced shifter boot. Rebuilt wiper motor & transmission. Upgraded to 3bar FPR. Replaced alternator & battery. Rebuilt cruise control servo. Upgraded to better (alpine) radio & antenna booster. Installed oil pan heating pad. Scheduled for 2011 (so far): Upgrade to KEP stage II pressure plate & 930 disc. (already have them) Replace rear main seal. (already have it) Replace right front fender. (already have it) Install motion sensor for alarm system. (already have it) Upgrade to 5/33bar brake bias valve. (already have it) Do light body work & repaint car. Upgrade to tall 5th gear. (210mph top speed & super-cruise capability) Replace performance tires. (for warm-weather use) Change engine oil. (have a case) Replace signal stalk. (already have it) Change brake & clutch fluid. Replace engine hoses. (already have them) Clean & re-oil K&N cone filter. (have the kit) Replace left-side fog light. (already have it) Pull out gauge cluster & fix gremlins. (grounds?) Get sheepskins repaired & install on front seats. Tune engine for maximum performance & fuel economy. Replace right-side Koni strut. (already have it) Upgrade shifter boot to leather. (vinyl sucks) Replace rear Koni shocks. |
Strip down 924S and prep for ITS. |
Sold Euro 84 924.
Bought 84 944. Did entire FOES. R&R'ed intake and such. Changed struts and shocks. Rebuilt the clutch hydraulics. Flushed and refilled entire hydraulic system. Did complete tune-up. That was the last 4 months. If I get my oil cooler O-rings in time I can squeak in an oil cooler reseal for the 84 too. I can't remember everything I've done this year but I keep a log and it may be worth checking. I know this year I did a 924 clutch, a 924 dash rebuild/heater refurb and a whole schwack of other stuff, including working on our Mazda 626, my wife's Niva, my brother's Quest (timing belt, water pump, suspension and some other stuff). I got the race car 924 up and running, and Mand and Scottie finished that after I tuned it and did the suspension. It's looking like I'm in the wrong line of work... |
Hmmm...
Drove about 13K miles Changed oil a couple times Swapped in a Thrush 2 chamber muffler that sounds awesome Paid a $90 ticket because my headlight switch crapped out at the worst possible time (at night in front of a cop and 5 min from home) Built a relay harness for the headlights so the dumb switch won't melt down again Shelved the K&N air filter because the OEM Mahle has no performance impact and filters better Finally got to replacing the rear main seal that leaked since November last year when I finished the rebuilt motor. Motor is dry as a bone now. New battery and alternator cables Installed oil temp gage in center cluster New complete clutch hydraulics New EBC red stuff brake pads and rotors all the way around New front wheel bearings Another new rear rotor because a loose piece of parking brake linkage destroyed the first new one. New parking brake shoes and cable. Finally got the thing working again...total PITA First compression test on the rebuild and results were awesome. 13K and about 1 qt/2500 miles oil consumption Swapped a bad lifter for a good used one Rotated tires and found that one of the wheels is in fact bent Finally unclogged winshield washer nozzles Got hit on the left front by a damn toyota driving through the median for a left turn lane. Just rebuilt both front brake calipers since the right front was sticking Wrestling with a bunch of random dumb little problems trying to get lights and horn working for safety inspection. Tomorrow I get to finish with the dumb problems, adjust the parking brake, and try to get the thing through inspection. I just hope for not much in 2011 since I'm in full time school now and just don't have the time and money to deal with anything major. Both the love and the hate has gotten stronger over the last year or so. Still runs great, looks like crap even more now, a few rust spots showing up here and there...probably going to be a rat rod by the time I get out of school and have money. Still cheaper to fix than buying some beat to hell used car and have to fix everything wrong with it, and alot more fun, plus practically more than half the car has been replaced by now. |
Spring is just around the corner and so are the drives |
Changed oil/filter twice (spring, fall)
Flushed brake fluid Replaced aftermarket air cleaner with factory unit Replaced hood and hatch struts Put on about 3K miles Put some smack down on a class competitor at local PCA AX events ;) |
I refinished a set of cookie cutters that didn't fit.
I sold the cookie cutters. Weltmeister sway bars. Schnell short shift kit. Repaint headlight covers after getting a huge chip. New tires for the phonedials. Front speakers. Buy 968 Wheels. Oil cooler gasket seals and while you are in there's. Wheel center caps. Brake rotors and pads. Vacuum lines. Found spare head. Washer tank. Saratoga sunroof. Stainless steele brake lines. Rear shocks. 27mm torsion bars. Casette box replacement hinge. Rear turbo valance. Sell Saratoga sunroof Built and rhino lined front air splitter. Refinish 968 wheels. All regular maintenance. |
2010 was a pretty good year maintenance wise
1) New clutch and p plate 2) New reference and speed sensors 3) Replaced DME and KLR (Thanks Pauerman) 4) New tires 5) lower and corner balance 6) Install 10 disk changer 2011 will be starting pretty good, but the lineup begins to look so-so as the year progresses Start the new year by installing the correct and proper Burgundy Plaid Studio interior in the Silberrosa 2) rebuild front and rear suspension (Feb) 3) rebuild engine and turbo (Mar) 4) compete repaint (Apr-May) 5) enjoy it (June-Dec) |
To summarise, I installed:
-Alpine SPS-406 4x6 speakers (front only) -Slotted front discs -Braided SS brakelines -Bendex HD pads (front) -944MAX chip tuned for 98 RON and did a few dyno runs. -26.8mm front sway bar with triangulating brackets, new bushings -18mm rear sway bar, new bushings and mounting hardware -Clutch changed Nov 2010 at 114,500 kms -track mat for drivers side footwell bought to install: -924 Carrera GTS front bumper -momo reclinable bucket seat (being reupholstered) -Billet PCG lightened pulleys and adjustable cam -New waterpump, thermostat, cam and balance belts and rollers -25mm 951 torsion bars -koni sports shocks (rear) Went on two cruises with some porsche dudes and did two track days (i think you guys call them DE's?) :D For 2011, conversion to '94 968 6 spd drivetrain |
You can add "New battery" to my list, had to buy one yesterday :mad:
Got the 944 running again after 6 years so changed about everything you
can except for the clutch :) This year I'll remove my sunroof, weld in a new roof skin, and finally install the rollcage :) PS Happy new year to you all! :cool: |
Changed the oil in August, cam tower seal blew September 5 and she caught fire. Since then I've only replaced the shift boot. She still runs, just not down the road.:D
Let's see, it's been a busy year.
I replaced an axle, then had to replace both axles when the one failed and picked up the power from the "replaced" defective one. THANKS NAPA! That was awful. Replaced the starter (for the third time), after the slave and master cylinders failed and leaked onto the starter and fried it (or it was just coincidence...) Bled air out of the cooling system that kept showing up; replaced thermostat. Also fixed the leaking power steering system while I was in there. Did a little stereo stuff and tidying up. Next year is another whole project. Replace timing belt/water pump, new tires, possibly fix the dashboard, do a little suspension work (bushing went AWOL, seems a little squishy in corners), and I also want to refurbish the wheels. These cars are a labor of love for sure. |
Last night (new year's eve), my list of things to do on the car in 2011 just went "ballistic". One thing that is guaranteed to be on it is:
Upgrade to larger fire extinguisher. |
The car was originally delivered without a sunroof, but somewhere in the 80's they decided it was cool to put in a Britax sunroof and somewhere in the 90's they used a lot of silicone to keep it tight.... |
Lets see. I decided I was tired of looking at the pristine 944 just rotting in storage. Only put about 800 miles on her in the last 4 years.
-Pulled the intake to replace intake gaskets and while I was in there I replaced all rubber hoses and vac lines. -New tires as the Kumho's were totally flat spotted. -Replaced my leaking clutch master cylinder and did the slave for good measure. It does have 190k miles on it. Now that she is all ready to drive, it is winter.:mad: |
Oil pan gasket
rod bearings power steering rack power steering lines clutch flywheel transmission cv joints wheel bearings(front & rear) I think that's it:confused: |
| All times are GMT -8. The time now is 05:51 AM. |
