Car Speakers
Do all the 944's have 4x6 speakers? I was reading on Clarks-Garage.com and it said that the 944's have 4x6 speakers. Is it just talking about a certain year or all the years? Anyone know what size mine would be? Or I gota snoop around? lol
88 944 2.5L 4cyl NA Zermatt Silver CE - Daily Driver - SOLD |
Proprietoristicly Refined
Front are 4"x6"
Rear can go larger... 4x6 speaker that fits front doors (solved!) - Rennlist Discussion Forums Note: It is the "depth" of the front speakers that is important. I think 1.75 inch deep is max without touching the steel parts inside the door. GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) Last edited by John_AZ; 12-21-2010 at 05:52 AM.. |
Garage Helper
There was also a 10 speaker option - In place of the door map pockets there were installed 5" and 3" speakers, including a crossover. The crossover also controlled a Tweeter that was placed on the upper front corner of the door panel. In the rear quarter window panel was another 5" speaker and a 1" tweeter. This panel also had a crossover that controlled the frequencies of those two speakers.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Alright thanks guys
. I think the front are 4x6 and back are 6x9 . The ones in my car now are alpine. I can tell they are gettin old though
6.5's are really easy to put in the rear of some 87's and all 88 and up cars.
Just remove the block off plate and make a piece to fill the gap.
-Doug D. 87 951 - Satin Black Metallic - well equipped 90 S2 Coupe-Silver- corner carver |
Coming up on your left...
I put in 4x6 in the doors and then a separate pair of tweeters on the a-pillar. It really sounds a lot better.
1986 Porsche 944 Turbo "S" clone ![]() 1998 Honda Accord ![]() Siena College '08 Manager, Mavis Discount Tire
Recreational User
Speaking of... anybody got a source for aftermarket 4x6 grills? Got some aftermarket oval 4x6s in the front doors.
'88 924S - Stone Grey Metallic |
I just ordered a set of these, hopefully they will fit! I Will post some pics after they are installed.
I put 6.5 speakers in the doors. Required some cutting and other work but it's very possible.
One speaker that I know for sure fits is a Alpine 426. Its there only 4x6 speaker. It fits perfect. Pick up 4 of those and get a KLA box and 8" JBL sub you will have a very solid stereo.
I just replaced my front door speakers with a pair of Sony Xplod XS-R4644 4" x 6" 4-way speakers and they fit perfectly and sound great.....they are only 1.6" deep, and the 4 mounting holes lined up with the existing pattern. The only problem is that the EOM speaker grills don't fit yet......I might be able to get them to work with some slight modification.
1988 944 Turbo Guards Red - Black Leather Autothority Stage 2 Chip Set Weltmeister Strut Tower Brace 1984 944 - Sold to rcecale |
I had a problem with the height of the center cone or tweeter sitting too high to use the OEM grill. It was possible to reduce the height of the cone a good 1/2 inch ans use the OEM grill on some speakers by performing some surgery on the speaker cone. 1) remove or cut away the top trim piece and 2) removing the spacer at the bottom of the cone. There was a screw thru the center of the magnet that held the cone in place that allows removing a spacer. (however I have a different (and maybe cheaper model speaker than above)
