-   -   Swapping Lock Cylinders (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/582937-swapping-lock-cylinders.html)
mikea100 12-31-2010 10:30 AM
I'm dealing w/ well known issue of ignition key not turning. I got ignition housing out part #171905851.
Is it possible to swap lock cylinders from trunk into ignition - '87 924s.
Thanks, Mike
Grandad#3 12-31-2010 06:15 PM
I believe they are two different part numbers and type of lock.
Porsche 924S/944/968 Ignition - Page 3
Cheers,
Larry
962porsche 12-31-2010 06:36 PM
no you can't swap them ! you can just repin the new one to your key .
mikea100 01-01-2011 04:25 PM
Thank you guys.
