Question Inside door panel removal
Can some one help me with door panel removal. I have removed all visible screws and unsnapped the plastic clips, but I am struggling on what to do with the inside door handle. Clark's says to lift the inside handle and remove the screw behind it. The problem is I can't find a screw here. The door handle bezel appears to be the only thing holding the panel on and I would like to avoid breaking it.
Old 01-02-2011, 06:10 PM
Yeah, it's in a tricky place. Pull on the inside door handle as if you were opening the door. It's right behind there.
Old 01-02-2011, 07:32 PM
hi and ther is a plate behind the door uprihte handel so you must lift the door panel upwords and then pull it . and it is a trick to put back make sure the plate is in its place
Old 01-03-2011, 12:33 AM
Not sure of your year or, if it's different on the later ones, but.. if it's an early model. Pull the inside release lever like you're opening the door. There is a cup pressed into the recess under the handle that just snaps in. Pry that out with a small screwdriver (carefully as it is known to crack) and you'll see the screw that holds the bezel on under that.
Old 01-03-2011, 06:44 AM
So that is where the screw is! Thank You very much. It is an 924S so it has the early interior.
Old 01-03-2011, 12:33 PM
