951 gasket help
im rebuilding an 87' turbo motor. ive rebuilt a 944 so most of this isnt new to me. except im getting towards the end of the engine build and i have a few seals yet to be used, and was wondering if anyone knew what any of them go to. what i have been doing is taking off the old seal, comparing to the ones i have, choose the identical one, then cross reference with the service manual and online. but i have yet to take any of these seals off anything. number "8" looks to be identical to the one i put on the oil filler sender... but the pack came with 2, so the filler already has a new one on it. any help would be greatly appreciated!
Old 01-04-2011, 11:23 AM
Proprietoristicly Refined
John_AZ's Avatar
1,2,3,4 in no order since size of each is a guess.....
Oil drain plug Aluminum crush washer seal
OPRV Aluminum crush washer for oil cooler
2nd Aluminum crush washer for oil cooler plug
5--Oil pressure sending unit Aluminum crush washer
6--?????????
7, 8, & 9
9 Is the small cam housing seal
8 looks like an AOS seal but could be from the cam
7 ???
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 01-04-2011, 12:17 PM
thanks. looks like you have confirmed most of my guesses. i do have a question about #9, the kit also came with a small white seal that i used as the cam housing seal.... so any other guesses as to what it could be?
Old 01-04-2011, 01:02 PM
#8 looks like the rear seal for the balance shaft cover.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 01-04-2011, 01:17 PM
Redline Racer
HondaDustR's Avatar
^+1. #7 looks like the rubber washer that goes into the block on a NA inside the oil cooler housing to support the oil cooler.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-05-2011, 01:03 PM
