All Spooled Up
How to greatly extend the service life of ball/roller bearings.
This information is in the recent "charging problems" thread. But I have deemed it important enough that it should be in it's own thread, "bearing" it's own title.
What you do, is pop a "grease injection needle" onto the grease gun's zirk connector. Then gently run the tip of the "hypodermic" needle under the inner lip of the rubber seal, with the opening hole facing into the bearing, and pump some grease into it. Wipe off any excess grease. This will greatly extend the service life (almost to infinity) of ANY bearing of this style.
When bearings are new, they contain some grease. But I have found that the amount in them varies greatly, from a somewhat decent amount, to iffy, to very little, to occasionally even none. I'm convinced that this is the reason why some bearings fail sooner than others. So I always add extra grease, even to brand new bearings. I don't believe that I have ever had a bearing fail yet, which I added extra grease to.
And you CAN also do the metal-shield bearings, but you need to pierce into the shield (use a sharp pick, so you won't damage the grease needle's point), making a hole in it, where you pump the grease into. Then seal the hole, by first wiping the shield clean, and placing a small "patch" made from aluminum (duct) tape, over it.
I'm sure that the bearing manufacturers won't be happy that I exposed this information. It can only hurt their sales numbers for replacement bearings. But my primary objective here, is to help out my fellow p-car owners. It might not be a bad idea for this info to go "sticky".
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 01-06-2011, 06:11 AM
Good info. While I'm not quite as cheap as I once was, I rebuilt the alternator in my 83 944 with parts from a 931 alt, including the bearings, which I repacked before installing them in the alt I was rebuilding. Part of my regular maintenance schedule was to remove the alt, tear it down and repack those used bearings. It's been going strong now for about 15 years in that 944, and I don't know how many miles were on the 931 alt we took apart to get the bearings from. The folly of youth turned into the wisdom of...what? Adult something-or-other.
Cheers!
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 01-06-2011, 08:06 AM
Wild man, brilliant idea. Can this technique be applied to torque tube bearings?
Old 01-06-2011, 04:24 PM
Redline Racer
HondaDustR's Avatar
It's also great for getting an extra clutch's worth of life out of clutch release bearings, too. It requires popping them apart (the flange IIRC).
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-06-2011, 05:12 PM
Great info! I will admit I have a bearing fettish and I do a lot of things to try to make bearings last longer!
Off to the hardware store...
Old 01-06-2011, 08:43 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Wild Man,
Great tip, Brother...
Looks like i'll be doing this in Spring, Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968 & 911 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 01-09-2011, 08:57 PM
Quality
phoenix_iii's Avatar
Pics for the win,.... =) (Help noobs, pics!)
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 01-10-2011, 10:19 AM
Redline Racer
HondaDustR's Avatar
I've just been in the process of tearing down a late 944 alternator and the sealed shields just pop completely out using a hypodermic needle. Makes it easy to pack grease into them.
Old 01-10-2011, 08:08 PM
All Spooled Up
Yes, popping them out is another way to do it. Can't UL any pics (using FF4b8), and can't seem to figure out what the problem is. There are also certain things that left clicking on seems to do nothing.
Old 01-10-2011, 10:17 PM
