no 12 v to coil
my 1984 944 sat in the last owners driveway for 6 years and I think it had water intrusion that entire time .there was standing water on the passenger side and mold all over the inside when I took ownership. I do not have 12 volts to the coil when the engine is cranking. dme relay tested ok. what do test next or just put in a good used dme? I dont know what to do next.
Old 01-14-2011, 06:19 AM
yarfk
kfray's Avatar
Lots of good information at Clark's garage.
http://www.clarks-garage.com/pdf-manual/fuel-16.pdf
Good luck
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 01-14-2011, 08:00 AM
If you are sure there is no 12V to the primary of the ignition coil, take the wire off the positive terminal of the coil then just put a temporary fused 12V from battery to the positive terminal of ignition coil and try to start and see if you get spark.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 01-14-2011, 10:14 AM
83 911 Production Cab #10
JJ 911SC's Avatar
+1. Did it on mine, car run with the jumper.
Then it turn out to be a broken fuse (not blown).
Since it been sitting around for a while, you should remove and clean all the fuse/fuse holder (1 by 1).
Good luck
Who Will Live... Will See
Old 01-14-2011, 01:30 PM
commdiver's Avatar
+1 on standing water in the Porsche 944's creates all kinds of wiring problems! Specifically all grounds and fuse links get corroded! Underneath drivers side dash way up there is some ground blocks you need to remove wires fro and clean up with scotchbrite. You will need to spend a few hours going through and making sure all electrical connections are clean and moisture free. This will save you hours chasing your tail on the other end trying to diagnose ignition and electrical problems!
You might want to pick up a spare early 944 computer that is a known good unit. I just happen to have one for $100 shipped! Good Luck
'83 944 ROW zermatt silver/black, sunroof & A/C factory deleted, houndstooth sport seats, 7Q - 220 LSD short fifth, F & R 23.3 MM 951 M030 suspension, 16" fuch's, manual windows, club sport mirrors, Blk/Wht gauges, rear seats & all sound deadening removed, 968 rear wing, fiberglass hood & 937 F bumper
Old 01-14-2011, 02:27 PM
