-   -   I need a quick responce ! ! ! ! When draining the cooling system... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/58631-i-need-quick-responce-when-draining-cooling-system.html)
overkill 02-01-2002 06:44 AM
the car should be flat(not on ramps)? Does it matter seeing that it has to be flushed til clear?
AFJuvat 02-01-2002 08:33 AM
Flat is fine. open the radiator drain, and let the coolant drain out.
If you want it to drain faster, take the cap off the expansion tank.
AFJuvat
