overkill's Avatar
Send a message via AIM to overkill
Where is the water pump located?....
The haynes book says that it has like two tubes connected to it, the lower radiator hose and the heater hose. Well I followed my lower radiator hose to what looks like the water pump, only if it's so then mine has like three. One hose being the lower radiator hose and the other goes some where and the last to this brown container floating above everything on the right side. The what looks to be pump is right next to my oil filter, slightly below it....does that sound right? Now the block plug on it would be under it or what, cause i didnt see it..then again it started raining so i didnt look to hard
{1987}944S - (SOLD).
Old 02-01-2002, 01:14 PM
The circle looks like an overflow / resivor tank for the rad. Water pump I don't know.
Old 02-01-2002, 01:38 PM
Send a message via AIM to gforces944
The one circled is the reservoir for the power steering. The other is closer. The sater pump is actually located right beside the oil filter. It's too hard to see it from the outside, it's practically hidden.
Rich
'86 944
221k miles and still kicks ass!!!
An Air Force Fighter Pilot was asked, "What's it like flying the F-16?"
He replied, "It's like driving a Porsche!"
Old 02-01-2002, 01:57 PM
least common denominator
scottmandue's Avatar
Originally posted by gforces944
The one circled is the reservoir for the power steering. The other is closer. The water pump is actually located right beside the oil filter. It's too hard to see it from the outside, it's practically hidden.
Yes, The thing circled is the reservoir for the power steering...
DON'T PUT WATER IN THERE! only ATF mercronII of III...
Dam that ventilator engine looks sweet... I came sooooo close to buying one!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 02-01-2002, 03:10 PM
Roger Hall's Avatar
go to the engine section of the manuale it should give you a better view. On my 81 924 the water pump is located below and to the right of the cam gear cover. On yours Im not sure. I am jelous of how clean your engine compartment is though.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 02-01-2002, 05:44 PM
