-   -   Help: Test Power to DME (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/587241-help-test-power-dme.html)
Srwilliams 01-22-2011 03:20 PM
I have done something dumb. I was hooking up wires to my headlights and foglights with no problem, all while starting the car to make sure I was hooking up the correct wires. I must have started the car 15 times throughout this process with absolutely no problem.
Then out of the blue the car stopped firing. I mean it keeps cranking without starting. I checked and I am not getting any spark to the coil whatsoever and the fuel pump is not coming on. I cannot hear it clicking on when the car is trying to start.
I changed the coil as well as the dme relay. Still no spark to the engine and the fuel pump is not activated. I am now trying to troubleshoot.
It is my understanding that I need to first check to see if I have power coming into the DME and then going out of the DME. Can anyone explain to me in simple terms how to do this. I have a 1987 carrera. I took the seat out of the car and I am prepared to test the power at the DME. I just do not know what pins to check or how to go about checking the power source to and from the DME
Any help would be greatly appreciated.
AKCJ 01-24-2011 03:23 PM
Well, if you want to run down a battery, I can't think of a better way than to start a car 15 times. That would do it. Charge up the battery and try it. You could check the battery voltage also.
You say you have a "87 carrera". Are you in the wrong place?
egil 01-24-2011 10:36 PM
If you started the engine 15 times and only let it run for a few seconds every time, I would also have suspected fouled plugs.
AKCJ 01-25-2011 11:50 AM
Reminds me of the time I flushed the brake fluid on my first car. I spent quite a bit of time pumping the brakes to get all the old fluid out and the new fluid in. The brake lights were enough to run down the battery so the car wouldn't start. . . .
To the OP - did you get it figured?
rick13 01-25-2011 01:09 PM
pull the dme plug, turn ignition to "on". get a multi-meter and check for 12v at pins 18 and 36. they are the 2 pins at the end of plug.
hope that helps :cool:
rick
944 Ecology 01-25-2011 02:10 PM
It was an 84 911 and he found the answer on the 911 board.
rick13 01-25-2011 05:18 PM
i have an '87 grand national t-type... errrr.... i need help with air pressure in my tires. battery has 12v, key is in ignition... oh, and it's only flat on one side :D
rick13 01-25-2011 05:20 PM
no no. i mean '84 le sabre...lol
egil 01-25-2011 11:57 PM
21W times two, probably, so 3.5A total current drain. Even if you kept your pedal continuously pressed for an hour, that would only rob 3.5 Ah from the battery. So your battery would be at well below 10% of its rated capacity for this to happen. I guess one could see it as a sign one should consider replacing the battery :)
